    TIPS:
KyleFrye05's For Sale Thread RIP 97 GTP aka Prixi
kylefrye05
All items will be shipped using USPS. All items are located in Columbus, Ohio.
Almost everything is gone! Thanks to all those that have purchased the parts!
I have another set of injectors that I was going to keep, but I'm going to sell them.
Bosch "Ford Racing" 42# Injectors (42 lb/hr @39PSI) - $150
'97 GTP PCM - $40
Pictures: http://s966.photobucket.com/user/kylefrye05/library/Forum%20Posts
Thanks,
Kyle
SOLD:
AeroForce InterCeptor scan gauge blue - $155
Gen5 Phenolic Intercooler core + machined lower intake Manifold - $350
Gen5 SC with MPS hub and machined snout w/o pulley - $160
Pullies 2.6, 3.2
DHP PowerTuner + Serial adapter, software, and bin file collection- $275
ZZP modified fuel rail w/regulator - $125
N* Throttle body kit with genV adapter and haness w/o MAF, TPS, and IAC - $100
XP cam - $225
CrowCams 125# springs + retainers - $100
300m input shaft - $315
3.29 7/8 chain and gears (2 chains both low miles 5-10k) $175.00
Aeroforce Wideband kit for interceptor - $100
ZZP 3 Pod A-Pillar gauguge holder 97-03 GP - $30
ZZP 3" aluminized cat back - $150 **Pick up Only**
Pulley, 3.5 - - $30
**Brand New** Walbro 255 with venturi kit - $90
Fuel pump bucket with venturi pump for walbro swap - $25
The XP cam works best with a blower, but I'm sure it can be used on a N/A motor as well. If you don't know much about the xp cam, it is made by comp cams. The specs are
  • 212°/224° at .050"
  • Intake Lift .325" (.520" lift at 1.6:1 rocker ratio)
  • Exhaust Lift .335" (.536" lift at 1.6:1 rocker ratio)
  • 116 Lobe Separation
I plan on going with 1.7 rockers, you think that can would still be streetable?
Sent from my Verizon LG G3 sexiness via tapatalk
1.7 rockers are useable with this cam, but you wouldn't be able to run stock heads. The valve guides would have to be cut down. The 1.7 rockers would put the lift at .553 intake/.570 exhaust. What are your power goals? I was at 334 wheel with this cam with room for more!
No worries, I won't be using stock heads. I'm getting 1.7 or 1.8 rockers, hardened pushrods, 125# springs, New seals, titanium retainers. No particular power goal, just seeing what I get lol. This is for my N/A camaro.
2.6 pulley is sold. Gen V is pending payment. input shaft, chain and gears, Cam, springs, and retainers pending pictures and payment. Those parts are still in the engine and trans. They will be removed this evening. Also DHP tuner, N*, and fuel rails Pending. If i have missed anyone please let me know. My inbox has been busy! Thanks
