    TIPS:
4t65-hd built trans 300m input shaft 7/8 chain 2.93 gears
TwinV6GTP
Looking for 4t65-hd built trans 7/8 chain 2.93 gears. These are optional but even en better. LSD 1" chain etc...
I have a trans built by Tim King about 5 years ago for a low 10 second turbo car. Has red z-pak clutches, diff squirter, etc. 0 miles on it. There is no input shaft or gear set currently. I would sell it as is for probably $600. Or, I could put in a 7/8 gear set and 300m is for $1500. Shipping might kill you though.
Not to hijack already, but what happened to the T80 idea?
still running strong. It's my rear engine setup. Front engine stays 4t65-hd. My stock trans did very well for over 200 runs. But I want a cleaner shift and a little safety margin as I will increase slicks size for more traction.
Remember I'm twin engine and it's going in a Nascar Truck 3600lbs with driver vs 4400lbs with driver for the GTP.
If I buy the LSD from GMR... would you install it ?
I'm in if you can !
Ben
That's what I figured. I knew you were twin engine...in fact I mentioned you in a post the other day. LOL
