Yarbeau
Car is a 2000 GTP. Installed a set of retrofits with Halos this weekend.
1.) First thing I did was disabled the key flash when locking. Pulled Map PGM fuse, Key back to ACC, pressed lock until it only chimed once. Voila! no more key flash.
2.) Disabled DRLS. Opened drivers side access panel in dash. Pulled the plug on the heatsink. No chirping or daytime running lights. Huh this was easy.
Wired the lights into place. I tapped into the side marker power for my halos.
During the day and the headlight switch to off nothing comes on. Perfect
Turning it to the Park lights I get my halos and sidemarkers. Perfect
Turning to headlights I get sidemarkers, halos, and headlights. again perfect.
When it is dark out It senses properly and headlights/halos/sidemarkers all come on. This was too easy.....
Now for the issue. The DIC and radio lighting is extremely dark during daylight hours regardless of which position I put the headlight switch. I cant make out a word on the DIC and the time is almost non existent on the radio (Factory). At night I can see the radio and DIC perfectly.
What did I do wrong? The brightness dial is turned all the way up as well.
Thoughts? I tried searching believe me. lets just say it hasn't been a very productive work day! Lol
