SomeDudeAtHome
When I hit the Highbeams the lights go off, the indicator stays lit up as if the highs are engaged.
I ordered new H1 bulbs and the relay from TRFS, going to wait it out and try upon arrival.
With the retrofit source harness linked by somedude I shouldn't have to repin anything correct? It will be plug and play?
I did not change any wires on the GM factory blue end of the plug. I simply swapped the white and blue wire pins.
Harness is plug and play. Only thing that has to be done is swtiching the pins which it sounds like you've already done. Before I had projectors and hit the high beams on mine it did the same thing yours is. Dash light on headlights off. Once you get the relay, harness, and projectors wired up correctly it will all work perfectly.
