2002 GTX Twincharged/Twin Intercooled
04 L32 bottom
ZZP st3 heads now with turbo stainless valves and #140 springs
Intense Racing stage 4 turbo cam
Devils Own meth injection
Gen V blower w 3.4 pulley
ZZP full size intercooler with 1/4" phenolic spacer
Frozen Boost w2a turbo intercooler
Frozen Boost type 101 front mount heat exchanger w bosch pump
Master Power T70 turbo, T4 flange, .96ar
Hallman MBC
Custom built turbo kit using zzp plogs
Custom 3" exh from turbo outlet to tips
Modified ZZP square style fuel logs
#80 injectors
Racetronix 255 venturi fuel pump with rewire and Kenne Bell Boost a Pump
running on e85
Trans custom built with:
1" ZZP 3.29 gearset with GMR 1" chain
ZZP 300m input shaft
chrome moly pump shaft
Raybestos blue plate special clutches with 3rd zpak
vb mods for pressure increase
ZZP st 2 half shafts
Trans go shift kit
KYB AGX struts with SSC lowering springs
Fbody front brakes, stock rears.
Dorman solid front sway bar with moog poly endlinks
aluminum Impala engine cradle with solid eng and trans mounts
505 whp @22psi
