In stock configuration, that nipples serves the purpose of supplying fresh air from the intake to the PCV system. It connects to the intake between your maf sensor and throttle body. Are you intercooled or is your stock pcv sytem blocked somehow?
tweeder- what throttle body are you using?
sounds like your stock pcv system should work fine and is definently better than a breather. basically, you need to uncap that nipple and route a hose from there to somewhere in your intake between maf and throttle body. your throttle body may have a nipple that serves this purpose in which case you could just attach it to that nipple.
