Need help on Rebuild
jayroca
Banned
Got the motor in a running drove it around and as soon as i pull in the driveway it dies out 4 codes pop up
P0122
P0405
P0403
P1122
P0122 and P1122 are TPS related (Throttle Position Sensor) and the P0403 and P0405 are Egr related .. i swapped tps sensors still the same codes pop up i even splice the harness from another car because i thought it was the actual harness any more ideas? Could it be the throttle body? Would i need to replace it? The angle of the metal piece inside where the tps meets? thanks
Sent from my LG-E980 using Tapatalk
Check the fuses both under the hood and in the glove box. That's a lot of codes chances are some are related if not all of them.
I think the EGR ones can be tuned out since the car doesn't have EGR on it anymore. Could be wrong Im sure others around here will know
Correct they can be tuned out i'll check the tps fuses and or fuse and see any more reasons i really dont think its the throttlebody
Anybody know the correct fuse for the throttle body position sensor?
Checked sensors and my tps and maf are at the right volts cant be my throttle body it was working on my last setup screen isnt f**ked has to electrical everytime i try and start it like its suckin juice from the battery and the starter checks out good any ideas?
You do know the two wires I'm talking about ..right?
The two you cooked when you hooked them to the starter... those two. I'd bet the cooking was bad for them.
