Oh Hai Dan...stalking you too it seems.
That's cute another Regal owner welcome!
Just think of it as a Grand Prix with classier features and trim.
As for the mod list...this is fairly current i think need to update that other thread:
Engine stuffs:
Modded JMB intake
LQ4 MAF
N* throttle body
Gen V with H bar removed
Phenolic IC
Port matched and smoothed LIM modded to match GenV with coolant holes plugged and bypass modded
ZZP stage 3 heads reworked for proper spring seat with 140# springs
Intense S3X Hybrid cam and custom length pushrods
1.8 yella terra roller rockers
Double Roller timing set
Pacesetter Headers
2.8" SC Pulley
5% OD Crank Pulley
Meziere Electric Water pump (For now)
Frozen Boost front mount with 97-98 overflow as a reservoir
Meziere IC Pump Assembly
Custom Fuel Rails with 60# injectors
Stainless braided fuel lines
SLP Powerflo exhaust with cutouts
Racetronix Fuel pump with Rewire
Trans:
300M input shaft
7/8 chain set
3.29 gears
Zpac clutches
Tight stack on 2nd gear per TEP
reworked valve body
Shift kit
(04 comes with the hardened 4th already)
Dex 6 and Cat fluid per TEP
Suspension:
AGX Struts
Vogtland Spring
09 Impala aluminum cradle with H-body LCAS
F-body front breaks
GMPP Front and Rear Sway bars
Customer Front strut tower and radiator braces
GM rear strut bar with Don Rome brackets
18" Sport Edition Rims with 245/45 R 18 Toyos
Interior:
Saab 9-3 front and rear Seat conversion
Indash Jensen double DIN DVD player
13 Regal door sill plates
Misc:
Aluminum Front impact bar
One off Projector headlight assemblies
HP tuners tuned
I think that about covers it....did I miss anything....like I said a few mods..shes fun to drive
