Gauge cluster+ wheel speed
Status
Not open for further replies.
TimMcCallum
Banned
Will the wheel speed sensor being unpluged on the passenger side cause the tachometer and speedometer to not be smooth? It doesnt flow smooth and goes up in increments. The passenger wheel bearing is unplugged atm. If not, what will cause that.
I'd check connections at the ICM, crank sensor etc. for starters. If they both are acting up, maybe check the connectors at the back of the cluster.
Tim.. the alignment of the planets might be doing it.
If you'd like some help, consider taking the advice given, otherwise... go post on FB and see how many off the wall, incompetent posts you can receive with wild suggestions.
I would hope not because they shoudnt be related. Its probably a ground like Bill said or your cluster is going out. If you can get a spare cluster I think they just plug right in and see if that helps. Never doubt or question Bill, he will change your name and come to your house and beat you up for questioning his authoritaw.
Sent from the Milky Way
I have no idea if you can even rebuild them or how too, I wouldnt worry about low miles unless your OCD like that. You still have to keep track of the previous mileage and record it or something for legal reasons if you ever want to sell the car I think.
Status
