For Autocross, keep in mind that if you change the suspension mounting locations, your car is automatically placed in one of the modified classes as opposed to one of the street prepared or touring classes. If you don't care about being competitive, no problem, because you will be racing against cars with much better weight distribution, $20,000 worth of suspension, 14" brake rotors, and 500 horsepower.
If you put whatever suspension components you want in the stock mounting locations, you will race against some FWD daily drivers and some novices in really fast cars who are fun to beat because they don't know how to drive.
Personally, I don't care what class I am in so long as I can pick off some Mustangs and BMWs.
IMO, a W body car is most competitive in a stock class with sticky street tires and a skilled driver.
But, if modifications are to be made, then a lengthened spindle that drops the ball joint down far enough to correct the roll center (or a correction made by a longer ball joint) would be necessary for a lowered car. Neither of these things change the stock location of the suspension. However, one could argue that the long steering knuckle does make that change by moving the ball joint mount.
And I did more checking.... Outonthetiles is right. A ball joint spacer does not change the roll center. It is the pivot point, not the final angle of the LCA that determines that. A spacer is just a waste of time and effort.
