    TIPS:
Phenolic Intercooler for your Gen3/Gen5 M90, L67/L32 3800's - LOOK INSIDE
Status
Not open for further replies.
Re: Phenolic Intercooler Gen 3 Gen 5 L67 L32 Eaton M90 SuperCharger 3800
Hi i am putting together a ssic kit and i am thinking about using your phenolic spacer in between the blower and lim
How much is just a 1"spacer ?
Do you think i can stack injector spacers?
Whats the difference between the gen 3 and gen 5 intercooler
Can i cut the lim for the ssic and use a gen v blower later
I have a 3/4" spacer currently.
Difference between my gen 3 and 5 intercooler is the length of bolts and the inlet opening.
I would NOT stack injector spacers. You need rails!
I don't no the exact dimensions of the exact SSIC so can't answer the gen 5 later question.
Awesome. I'll send u money tomorrow. How long does it usually take to ship?
Priority mail with tracking is 1-3 days depending on how close to PA you are. I need one business day to get to post office.
$554 for gen 5 with bolts Includes shipping to USA, PayPal friend or family.
Add 3% for goods or services type paypal. ($571)
So what's the difference in benefits from your old core i got to the new design?
New design works on stock LIM manifold. PCV works without drilling a hole!!!!!!! Should work with stock gasket. ( not verified, I've never installed without RTV)
Intercooler is 2.25" thick, core is slightly bigger than zzp. 1-1/2" thick phenolic pre-sealed ready to install.
Currently selling gen 5 as the gen 5 manifold air inlet is quite large. GEN 3 version will also be for gen 5 manifold.
Custom maximized inlet and outlet openings possible with matching machined manifolds.
Aluminum gasket surface is very durable.
Didn't count the fins per inch but .....(looks like 32 fins an inch)
Most any online auto parts. It's a Lincoln mark VIII core.
Gen 5 ready to ship with bolts.
$554 including shipping to USA PayPal friend.
Quick question im hearing the phenolic cracks from the high heat is this true
Sent from my SGH-T999N using Tapatalk
Where did you hear they crack?
Only crack I saw was from prying apart. New design has phenolic only in compression. All bending and tension is in the aluminum.
I saw zzp translucent amber intercooler with cracks it was there first version. They had pressed sleeves into the holes. The sleeve cracked the amber material. I think there is a picture somewhere in this thread.
Ah my tuner was telling me so I figured I ask you first hand will I need a turn down adapter for my 05 gtp with the new ic?
It is 2.25" same as ZZP you may need turn down.
Nope they don't tend to crack.. I've had my Sseilmnop IC for what going on 2 years now.. and it's been on and off dozens of times as well... also ya you will most Def need a turndown for his new IC.. The old design I have is slightly smaller in height and I just got away with not using one for a while but I had to dent the sheet metal on the underside of my hood for the TB to clear
Gen 5 intercooler and bolts ready to go.
Bolt on PCV works!
No lower intake modifications required!
Status
