    TIPS:
Phenolic Intercooler for your Gen3/Gen5 M90, L67/L32 3800's - LOOK INSIDE
Status
Not open for further replies.
Re: Phenolic Intercooler Gen 3 Gen 5 L67 L32 Eaton M90 SuperCharger 3800
Good info guys hey im getting one just meed to get my fuel pump issue fixed
Sent from my SGH-T999N using Tapatalk
Soo what would happen if you hooked this up to the AC evaporator?? Cus that's what I originally thought this did lol.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
It was the most extreme intercooler I could think of. Literally using the air conditioning to cool the intake.
thats been done but put it in the air intake.
this dont work quite like that. this gets its own core with antifreeze and a pump to its own radiator you mount in the bumper to cool the coolant.
Will have one ready to ship Tuesday.
Of course fsic
New design works on stock LIM manifold. PCV works without drilling a hole!!!!!!! Should work with stock gasket. ( not verified, I've never installed without RTV)
Intercooler is 2.25" thick, core is slightly bigger than zzp. 1-1/2" thick phenolic pre-sealed ready to install.
Currently selling gen 5 as the gen 5 manifold air inlet is quite large. GEN 3 version will also be for gen 5 manifold.
Custom maximized inlet and outlet openings possible with matching machined manifolds.
Aluminum gasket surface is very durable.
Didn't count the fins per inch but .....(looks like 32 fins an inch)
Full size
PCV works with stock manifold
2-1/4 thick same as WBS and ZZP
$554 for gen 5 with bolts and shipping 50 states
Gen 5 intercooler and bolts ready to go.
Bolt on PCV works!
No lower intake modifications required!
Interested in a gen 3. Noticed you said "gen 3 will also be for gen 5 manifold" does that mean it requires a gen 5 manifold? Thanks man.
I can make it bolt on to a gen 3 manifold or a gen 5 manifold. I currently have one done ready for gen 3 M90.
Let me clarify. The intercooler will work with either manifold. The bottom of intercooler outlet will be bigger and match gen 5 M90
You got a gen v ready ?
I do not. Can have ready for Monday shipment.
What type of phenolic material do you use for your spacer
Status
