Odi
Donating User
Still doesn't change the fact that the axle geometry is affected.No spacers no vibrations on my coilovered Gxp my 97 gtp with SSC never had those vibrations either.
if you're axles point upwards then you have issues an geometry is affected. My axles are level.Still doesn't change the fact that the axle geometry is affected.
Not talking about the GXPif you're axles point upwards then you have issues an geometry is affected. My axles are level.
It doesn't matter Gxp gtp gt all wbody suspension has the same problem if you slam them. I'm referring to my gtp in the previous post btw.Not talking about the GXP
good for you.It doesn't matter Gxp gtp gt all wbody suspension has the same problem if you slam them. I'm referring to my gtp in the previous post btw.
This.
Also, depending on your mileage, your motor/tranny mounts could be quite a bit worn by now making the geometry even worse. The pair of solid mounts are like $40 shipped, why not just get the spacers and replace the mounts at the same time.
When I lowered my car I had a little vibration at first, about the first week or so. I decided to change the trans and motor mounts and the vibration completely went away. It feels like it did before I lowered it when accelerating now. Definitely do your mounts when you lower.
No vibration at all anytime.No acceleration vibration ? I call bs
Sent from my Nexus 4
What are you 4? Grow Upgood for you.
97, like I said already though most vibration happens when people don't take care of other things first. If you have motor mounts and axles with 100k on them...expect that when you lower your car you will have issues.If I may ask, what year was this GTP and what was the setup? If I can get away from modding everything just to get it a little closer to the ground I would prefer that. I'm not trying to slam it like some silly ricer, I just want to get a better center of gravity for cornering.
Pretty much. I'm using speedbuilt stb's and the difference is negligible.Skip the braces, save yourself the money.
You'd notice zero difference because you are already lowering the vehicle and adding better sway bars and links.
Try getting proper stb's like speed built so they mount around all 3 strut bolts
