Mods needed for 3.5 S/C pulley?
See that's the thing. I don't want a 3.4" :th_laugh-lol3: lol I want a step down from a 3.4". Just a 3.5" That gets the car going, but isn't too crazy.
The difference between a 3.5 and 3.4 is so minor.
In car tune means someone who knows how to tune rides with you and tunes the car
No, its when a tuning program on a laptop is used to log data from the car,then you tune the car based on what your seeing.basically.Your car isn't "chipable".lol
Edit:wasn't saying no to you redcomp, just a slow but typer on phone.lol
Alright. Thanks for the information. And what does he tune the car with? A chip? Some sort of device? Sorry for all of the questions. I've been wanting to know a lot for awhile.
It means someone actually driving your car and making adjustments to your tune while monitoring different parameters as opposed to calling zzp or intense etc and getting an off the shelf tune.
Ohh gotchya. And based off of how the engine is running, and air/fuel ratios, compression, psi etc. that's how I know if I can drop pulley sizes or not?
As far as "scanning" most people run a Aeroforce scan gauge. You can actively monitor parameters such as K/R, AFR, and so on. Given the mods you listed you and a proper tune... you might be okay but with significant retarded timing would be my guess. But that all depends on what day of the week your car was built.
It means someone actually driving your car and making adjustments to your tune while monitoring different parameters as opposed to calling zip or intense etc and getting an off the shelf tune.
This. It's different from just ordering a generic mail order tune like ZZP etc where they just doing adjustment that may have worked on other cars.. A in car tune will be tuned to your car specifically. So adjustments can be made
But you need to make sure the person doing the "tuning" knows what they are doing otherwise you will have a bad day and no more car :)
I know a great mustang tuner but that doesn't mean he knows my gp. I'm not knocking your brothers knowledge I'm just saying be careful.
True. He used to be a street racing fanatic like I'm turning into(a little bit) and so I'm guessing he knows how to, but there is a chance he doesn't. So in conclusion, you guys would recommend a 3.6" pulley and I should be good to go?
"Should" be but again for the 1 millionth time you need something to scan for knock. What works for one car doesn't mean it'll work for other cars. Without scanning you really dk where the motor is at. I would not even touch the stock pulley until you have something to scan with unless you enjoy changing it and when you chip a piston I'll be the first to say I told you so.
