What did you do to your Car today?
Status
Not open for further replies.
Well get your parts trunk down here and blast my nuts........you know on the car.....
Sent from my Galaxy Tab 3
40min drive for pb isnt worth. I have air tools so I'll break stuff or get it loose. Only worried about the LCA bolts giving me problems I dont want to replace them. Tat and I pickdd up a t55 bit for 6 bucks. Lol
in the process of fixing body parts, drivers side fender, both rocker panels,
the car will no longer have the SE version of the rocker panels, instead just the base model version
I had the hardest time getting my right torx head lca bolt out for some reason, I got the nut off the top but the bolt was seized inside the bushing. I did all sorts of stuff, hammer, impact gun and vice grips on the bushings, etc. What finally worked was a 3 arm puller and using an impact gun at the same time to make the threads grab the bushing and pull itself out. Took almost an hour.
Status
