Sunroof
94grandprix
My sunroof on my 98 gtp seems to not be shutting properly, when it closes the passenger side rear corner do sent pop up in place, I have to push it up on that corner and if I push to hard it will come up and I can see outside through a crack, anybody else?
Sent from my SAMSUNG-SGH-I337 using Tapatalk
have you tried to adjust that side? there is a couple screw that can be moved slighty to help remedy that.
I don't know the answer to your problem, but if you ever decide to replace it take it from someone who has done it...it's extremely easy! A few bolts here; a few there; unplug it. The reverse when installing the good one and you're done. I give it 45 minutes..1 hour tops. Of course you have to take the headliner down partially not all the way off, but that's included in the time it would take to replace it.
Ya that's what I meant like a windshield,and scottydoggs I will when it doesn't rain
No... it's all one assembly. Like i stated before it's easy to do. If you're gonna do it and have any questions just let me know.
Ok I'll update when I find out something and can I just pull the Grey cover out, the one that covers the sunroof cause it's loose and binds the sunroof or would that require taking the sunroof out?
the slider is part of the sunroof assembly.The only thing that you would have to remove from that area to get the headliner down would be the trim ring
I'm saying the slider thing isn't any good anymore can I just pull it out without taking the headliner down
There are four torx head screws that attach the actual glass to the arms that move.Its one of those most likely.If that is not causing the issue,it could be that the cable on one side has jumped a tooth on the motor.That makes one side have more pull than the other and cause it to open and close unevenly.When it closes it wont lock on that side and will stay popped up a little.
The answer to that is no. You would need the sunroof regulator assembly out for that, and you almost have to break that slider to separate it from the regulator. I have one car where the slider slides around like crazy, another that gets stuck, and another thats just right but the regulator is bad, go figure. Your trouble may just be the screw that fell out needing to be put back.
