Burgundyman
I should be good with my pry bar..:->)
Yes each one goes a certain way, the flat side goes up against the washer and the pointed side goes into the sway bar and LCA.
Oh that's my fault, I need sleep lol. I don't think you can put them in wrong, either way is fine.
good and tight always seems to work. line up the nut, pin it.
Yeah I could only get so much torque on a 8 inch wrench, just pulled one off and re-installed on a regal gs yesterday. Tightened it until I couldn't go any more with one hand and put the pin in.
Good to hear, I'll be going through the same thing and more soon on mine. I did upper control arms on a charger recently and getting the bolt to go through the bushing and the frame was a pain too.
Sounds good. Clunking is gone right?
How's your alignment? Also double check that both o your strut mounts are tightened the same amount. Its also plausible that they didn't get put together properly.
After a week or so go back an make sure all your bolts are tourqed on the control arms etc...
Strut mounts defective?
