Throwing codes
Thanks. I'm still chasing the misfire problem.....I'm looking at the coil packs next. Still need to clean up the connections to see if that helps.
Ok. Thanks. I'll try that. The car runs perfectly with no misses until it warms up, so, maybe a vac leak is the problem.
spray the injectors too, the TB as well, around its gasket area and vac lines.
may want to pick up a used icm, never know, they do go bad.
what's the silver thing in the picture? It made a air leak sound when I moved it with the car shut off.
You have a boost gauge that shows vac on the car don't you?
If so whats the vac reading at idle?
Seized roller on a lifter that wiped out the cam...sent metal all through the engine...we hoped we got it all flushed but ended up having to replace the engine shortly thereafter.
