Found this plug,
And this plug,
My feeling is, that this stuff wasn't needed after all the turbo stuff was added, but I'll need you experts to tell me...........
I re gapped the plugs to .045 and it seemed to help the way it runs at idle, but, I still have misfires, mostly on cylinder 2.
I swapped coil packs to see if it moved and it did not. One thin i noticed is som green corrosion on the coil pack prongs. I tried wiping it off before I reinstalled them, but, I think I'm going to take them off again and clean them better.
The o2 sensor in the pic does have a pigtail. here is another o2 sensor in the downpipe plugged in. Do I need 2?
Now you know why my hands hurt.........
The only two codes I would be concerned with are the last two, I'd clear the codes and make sure that your Primary(Bank 1) O2 sensor in the upper downpipe behind the turbo is plugged in securely.
I'd clean up your coil teminals and get rid of the zzp wires also.
Does this car have an aftermarket cam installed Traildog? If so it could be responsible for the P0300 missfire code
My L67 runs and idles perfectly with the AL 103's gapped at .035, I ran AL 104's gapped at .035 before the cam and other mods previously and it ran and idled great then aswell...but hey every car is a little differnt
This car ain't halfassed, he just needs some help from folks who know about turbo setups.
