Wheel and Tire Opinions/Help
center bore is fine, won't need to be opened up at least.
the offsets are going to be pretty low for what you're getting. (the one's you're looking at are the 18x9.5 +30mm ones, yes?)
could you run them with a little fender work? probably.
If i roll the fenders and run with negative camber, would it still work do you think? The other wheels (saleens and AMRs) have the same offset as those
i would think so, but no one's going to be able to tell you for sure. you'll just have to do it and hope for the best.
