Budget Comp G. 2.5" pulley = no belt slip
Re: Budget 04 comp g running total $3688.89
Is it just leaking from one of the lines running to it or is the whole thing just busted?
if it was accessible leak i could braze it up solid for ya ;)
learn quite a bit while being an AC tech, its no different than a condenser coil LoL
I can't see where it's leaking so i just put a **** ton of jb weld on it lol Hope it holds
You can actually solder refrigeration systems. Solder will hold pressure well. Soldering aluminum I don't think, aluminum will conduct the heat everywhere rapidly. TIG weld or MIG set up for aluminum.
