Bronco Boy
Donating Users
Post #119 is what I got from TRS......curious if one had access to Butyl if that wouldn't be preferred??
http://www.grandprixforums.net/thre...ors-97-03-GP?p=1172440&viewfull=1#post1172440Post #119 is what I got from TRS.
I haven't done my final fit, so I can't comment on the grinding part. I know mine is close, but I all the info I have accumulated says nothing about it. And I'm still unsure of how the alignment should be, so I will let others advise on that.OK, So i placed projector in housing and placed in bracket and put on car. Kinda answered my own question in reference to being aligned properly. So just like LS1 stated, will have to shave a lil to make it sit outwards. Question I had in respect to grinding on one corner of the projector bowl, is that when not ground, that corner seems to be resting on bottom of housing therefore making the shutter sit horizontally crooked in respect to reflector grid lines running horizontally across back of housing. So im trying to get the flat part of bowl on top and bottom to line up horizontally equal so that the shutter and projector would sit horizontally correct, or am I thinking to much, lol. Is it just the way you took your pics, but why does it seem your horizontal line on the wall is crooked in respect to the floor?
Thanks. It'll be even better when I finish the project. LOLDamn that's a very nice link^^^^ Thanks !
This is kind of why I put the project on hold. I had to angle them to get the alignment in check, but I can't see where others had to do the same thing. I would have never thought you could get that much alignment out of the bracket without the housing looking all crooked.Damn, he sure made them sit all angled like in the back of the headlight capsule. I just made mine sit flush with the back so the lock nut could go all the way down. Then just used the headlight backet itself as my adjust for getting the beams lined up.
Thanks. I just re-read that and am starting to remember it. LOLI do like your link Bronco. In your July 16th pics, you do comment about trimming the projector housing. What did you have to do to it?
Ok, the cut that I forgot I made was to the top left corner (looking from the front) of the projector. In the picture, looking at it from the rear, it is on the top right. Looks to be about 2mm, which gave me the clearance to clock the projector to get proper alignment.
