So in your opinion, is it still worth the hassle and time to fab an OEM housing and go that route, or would it be just as well to go this route with the H1 retro? Obviously be a lil more expensive having to buy the housings from them instead of OEM housings, but seems that you wouldnt have to worry as much about alignment issues since would be mounted to brackets instead of a mono threaded nck sticking out the back. One concern of mine with OEMs is the fact that over time, the fitting could come loose and the projector would spin within the housing causing alignment to be off. And that stuff would absolutely drive me crazy, im kinda a perfectionist and always want things to work the way they are supposed to without fault, which is sometimes unavoidable. I like the way the OEMs look over the Spyders, hence one unit, but like the Halos better in the Spyders, hence i can get CCFL, but dont like the fact that CCFLs only come in one color i believe. Damned if I do, Damned if I dont, lol
