sseilmnop
LaBarge Supercharged
This is true.
This is also true. What you don't seem to understand is that the term "viscosity" is not the same as the term "flow rate". Synthetic oils have a better flow rate at lower temperatures than conventional oils. (while still being the same viscosity) Viscosity does affect flow rate(which is why you suggest running a thinner oil), but flow rate doesn't affect viscosity(which is where you're confused). Hope that clears that up for you.
Definitely not clear
Synthetic oils have a thinner viscosity at extremely low temperature such as -60
Same grade Conventional oil is solid at -60
