GTPpower
All the screen shots from tourqe in the world do nothing to relay real engine data. You can show your trims but what fuel trim cell where you in at the exact same time as you displayed ? What's your injector duty cycle?
And as far as tunes go if the the stoich of e85 is 9.8 ish and the stoich of gasoline is 14.68 and that's not changed in your stoich AFR settings how in the hell does your pcm compensate that extra 30% fuel and than adding more for power enrichment? Luckily your not straight e85 or else you'd have some real issues right now.
:th_bangheadonwall:
FUEL TRIMS!
