Fahrenheit
Was driving around my 03 GT without a problem. I start to notice a sweat smell and then white smoke. Didn't over heat as I drove it home. When I got it home I looked under it and sure enough some coolant was dripping. Checked all my hoses and they were all intact. Even the plastic elbows coming off the water pump. Start to think I blew a head gasket but It doesn't seem to be coming from the block/head joint plus when its head gaskets its usually leaking internally. While reeving the engine I notice the upper rad hose collapse when the RPMs go up. Also seems like the thermostat doesn't open up. So I got a new thermostat/Rap cap and bam no more leaks. I bleed the system with that little screw. I Drive it around for a bit and all seems well except now I don't have heat. The top heater hose gets hot but the lower one stays cold, clogged core right? Makes sense cause I had a lot of mud in my coolant system which i'm thinking is from my LMG job I did last spring. Also changed the oil while I was at it and no signs of water where in it. So here is what i'm thinking...
Broken radiator cap and or thermostat caused abnormal pressure in the system
Due to the pressure someplace somewhere caused a leak
Also due to the pressure it forced some of that gunk up into the heater core clogging it
Does that sound like a reasonable series of events? Heater core job doesn't look to bad based on wright up. Gonna try some coolant flush first, any recommendations?
Also why does crap always bust when my driveway has snow on it.
