ericspecullaas
Lets see I just finished up a 15k website so yeah trt it son here is the site acmetestsite.com
How do you know. First off I dont know you well enough or even were your at so![]()
got some tires for my flaking 17in tstars...think i went too small 235 45 17...holy wheel gap! getting new struts next week!
Overheating? No. That temperature will cut your transmission fluid's life in half though. ASE manual says that the optimum transmission fluid temperature is 175*F and for ever 20*F it increases, you cut the transmission fluid life expectancy in half. Mine was running about that hot so I put and Ford Exploder transmission cooler on it. Haven't had the temp go above 173*F since.Drove the 04 gtp around this morning and decided to change the scenery on my dic and stumbled upon this Are we supposed to be this hot?
Sent from my iPhone
That wouldn't have an impact on the transmission. The radiator is heating it up to the same(ish) temperature as the engine itself. Like I said, it's not bad for the transmission, but it's bad for the fluid. You'll just have to change the fluid sooner than you would with a cooler...with temps like that I'd change it every 30K or so. My transmission has 230k+ on it, so the closer I keep it to 175, the happier she (and I) will be. Here's the cooler I installed on mine, red hose added 153 Horsepower of course:I've been driving it with a bad alignment, after the whole rack thing the dude who helped me screwed with the tierod.. Only reason I've been driving it is to get back and fourth to my new job, could the alinement be putting enough stress on it to heat it up like that? I don't drive it crazy I'm actually pretty soft on her .
Sent from my iPhone
