VHT Nightshade
mine is kinda coming off and i did mine a year ago just one coat of VHT... try using VHT and doing some clear coats and it'll last for a lot longer....
Input: send to Flip and have it done right.
Output: never have to worry about it
clear coat fixes everything,
prep, scuff, clean, tape off, clean, then tint, then clear, let it dry for 24 hrs. then wet sand with 2000 grit paper with soapy water, then buff with rubbing compound till its clear and shines.
I did that and it seemed like it was coming off when i used compound and then was usimg wax on it, but i sprayed it again this morning and going to clear it again later. Thanks!
Sent from my iPad using Tapatalk
How many clear coats did you use when you first applied the VHT? If you can remember. I applied 4 coats. Took a long ass time to get the job done but I held a pressure washer to the tail lights for a while on full boar to see if they'd do damage, none yet and mine have been on for a year. I also only have 1 coat of VHT on too.
i use 2 light coats of vht, and 5 coats of clear, let them dry for a 2 days i think, then wet sanded and buffed. its got to be 2 years later now, they look just like the day i finished them.
that polish really helps. There's a loser that half asses his tinting and he tints for other people.. Looks like ****
every year i also run the pc over them with liquid compound, and then wax with the buffer as well. this takes out any small scratches they may have gotten over the year. the regal you kinda pop the trunk and grab by the top of the lic plate so your palm touches the center section of the tail lights and gets light scratches here and there, pc takes it all away.
crappy cell phone pic, but they still shine just like this, no flaking or nothing.
i really cant wait to fix the bumper, its awful looking.
fixed that crappy bumper up.
