Gtx has a turbo!! lol
Re: started tear down of the 01 motor
Ok so I got a little more work done today, not much but got the back header off last head off, and took the transmission off the motor. Now my question is how do I get the pulleys off? Can't I make something to take them off or something haven't looked to much at it trying to relax now before work in early morning
Ok going to start to order parts here soon what gaskets do I need besides heads, headers, lim, valve covers,supercharger. I am going to order a nic cam if I sell the parts, if not I have to wait till my payday.
And for parts feel free to add some if I should get more
I have ported heads
105springs
Gen v
Push rods
Nic cam maybe still just getting new
Parts I need
Gen v tb adapter, should be getting soon
3.4 pulley and hub, should be getting soon as well
Cam bolt? Not sure if I do or not
Ls7 lifters
Timing chain
Im looking for headers as well
What do you guys think I need more I know im missing a gasket or two
Got the cam and lifters had to use my card and my grandfathers pay pal lost 10 but saving it from the website you giys gave me.
I also got the tb adapter money was sent now waiting on shipping number, im also getting the 3.4 shipped out soon, im going to order a few more things before I run out of cash lol
This should be a pretty kickass setup when it's done, I'm looking forward to it. Don't forget head bolts and rocker bolts.
Since you have a LIM off the engine already, did you know about opening up the coolant holes at the TB end of the LIM?
Takes a little bit of time and a Dremel\Grinder, here's what mine looked like after I was done:
I actually have the re useable rocker bolts but not heads can I re-use mine? And its going to be fun to build and drive.
But I haven't seen the lim opened up like that, I have seen when they block the holes though
When you block the holes you restrict the coolant flow from the front head to the back head a bit. Opening those holes up compensates for that. I'd get new head bolts, I'm sure the stock ones are TTY. Even if they aren't, that's a big risk in my book.
Ok so what are advantage and disadvantages of porting them is it worth the time?
Get head studs. Thank me later
Lol I can't thank you guys enough,
So do I need a cam bolt as well and anything else I should order so I don't get delayed on my build?
You don't need to do it for the Gen V, it's just something to do to the LIM to make it flow (coolant) better. The Gen V doesn't matter in this case. If you plug the holes that run coolant through the TB (on the top of the LIM), then I would consider this mod a MUST.
Here's the holes I'm talking about plugging, I used some dimes ( I can elaborate on this more if you want), but most people tap the holes and put plugs in them. I had no taps and no plugs, but I had a dremel, some dimes, and some RTV.
Well not the gen v but I have to.match up the square on my 98 lim didn't take the lim from the 06' but ok so what is what I see the two holes that go the tb you blocked with the dimes what hole did you.port and open up on your first picture?
The LIM in the first pic is upside down. The hole from the first picture is directly under the EGR tube you see in the bottom of the second pic. There's an end cap that covers them up, I believe the LIM gasket set comes with a new gasket, or you can make one yourself.
