bsharpminor
Hello all. I'll start by telling you what I have, then what I've got going on, then what I plan to do. I'm looking for any advice on the process.
I've got a 2003 GTP Limited Edition. 99,xxx miles.
Mods:
K&N Intake
3.4" SC Pulley
1.9 Modified Rockers
60# Injectors - running E85
AL104s
180* T-stat
Speed Daddy Headers - Cat Delete
Over the last year I've been working on figuring out a crazy knock situation. When I bought the car it had the 3.4 SC Pulley with only the intake as a supporting mod. When we plugged it in to tune it, I had something like 14* of knock. I have been trying lots to get rid of it since, hence all of the other mods. After throwing E85 at it, I am sure there is no knock; however, I am still seeing as much as 5* of KR. I know it is false knock because after doing one pull during tuning, I saw 2* of KR, on the next pull we added 9* of timing and I still got 2* of timing. If it were real I should have seen 11* of KR. I also have a buddy who is running a 3.0 pulley on E85 with stock manifolds and no knock. 105 octane can do wonders with knock.
Did some looking under the hood and few things could have been slapping causing the FKR. Put header wrap on sway bar because there are lines that are close/touching. I put dynamat on trans dipstick by the brake booster and by the crossover pipe because they were close. I also put a piece of dynamat on the front knock sensor because the oil dipstick was suspiciously close/touching.
I am still seeing situations at WOT where I will see as much at 5* of KR on my scanguage yet. AHHHHHHH!!
While I was under the car putting the dynamat on, I saw a couple drop of oil hanging from the oil pan bolts. I suspect oil pan gasket.
So I am really close to 100,000 miles and was planning on doing my transmission maintenance and I have a shift kit to put it, and while I have the car on the lift I am planning on changing the oil pan gasket. I've watched "Changing an oil pan in a 2002 Pontiac Grand Prix How-to" Changing an oil pan in a 2002 Pontiac Grand Prix How-to - YouTube and read Oil pan removal: my how-to, my hell.
While doing this job, is there anything else I should be looking for?
Any other thoughts on my false KR?
Would swapping to this poly engine mount help, since I have to pull it anyway?
Where do these go? ZZPerformance - Poly Motor Mounts #ZZ-PLYMM-GP
So typically when I ask several questions in a thread, people get stuck on one topic. I challenge all of you to diversify your thoughts.
Thanks a bunch,
B#
Mods:
K&N Intake
3.4" SC Pulley
AL104s
180* T-stat
Thanks a bunch,
B#
