My official LeMons car thread questions and answer??
More pics coming this weekend of the new front bumper brace installed and modifications to the front bumper cover to improve air flow....stay tuned
hey man, wicked car, cant wait to see it boosted!
how hard was it to removed the full dash? im wanting to replace mine and fix some electrical issues at the same time.
any pointers?
Installed:
any pointers?
The dash is a PITA to get out. you'll have to drop the steering column, remove the center console and lots of wiring to be disconnected. Just take your time and take lots of pictures as you go along. No realy easy way around it. Since we just stripped it all out we didn't worry too much about how we romoved it. Sorry I couldn't help any more.
what are your plans to help reduce chassis flex?
We already have a 8 point roll cage installed and no need for reducing any more chassis flex. Currently we run a 36mm front sway bar, GMPP rear bar, Moog rear end links, energy suspension front end link bushings, Moog tie rod ends, Monte Carlo aluminum subframe, and strut tower braces. This past weekend I did the front and rear GXP brakes and we run GXP Bilsteins with Eibach springs. I think the only real upgrade we have left is coil-overs, and wider tires for a better contact patch, currently we have 245/45R17 Dunlop Direzza Star Spec's
I've always wondered what stops you from buying a modded car for cheap? Like what if I bought a GTP with a gen v blower, cammed, intercooled, headers, 3.1 pulley, etc. all for $500?
I thought they made you run Falken tires? Maybe that was only one of the races by buddies team was in. He said both options were terrible traction, but everyone was on them so it was equal. He said they were so bad he spun out on pit road on them in an XJ. :burnrubber0::burnrubber0:
as long as you keep your budget within check and in the good graces of the judges then you can run almost anything. Mind you this is an endurance race and you want to do everything to make the car last, like keeping your cooling system in check along with trans temps and a good set of brakes.
You can run any tire you want as long as the minimum tread wear rating is 200 or higher...no race compounds so any brand and design of tire is ok.
We just installed the GXP front and rear brakes with Carbotek pads, will take pictures this weekend and post them up. Also we are headed to the Pontiac Southern Nationals and will be entering the LeMon car, just need to see what catagory the car will be slotted into. Wish us luck.
LeMon car at its first show. Getting lots of looks, laughs, and questions. Needless to say its a big hit.
Now some more pic's of the GXP brakes front and rear installed, additional cooling in the front bumper, and our additional night time race light. Oh....and I won first place in modified GP class 88-08, first ever car show at the Dallas Pontiac Southern National car show
Just wanted to find out if any locals in Texas want to come out to the race on the 28-29th of September. Address is One Performance Dr. Angleton TX 77515. Post up if you can make it, we have a garage rented that is just under the grand stand area so there will be shade and a place to relax.
