What did you do to your Car today?
Status
Not open for further replies.
oh my god there it is. My comp g has a keyhole and i never knew. Its an early 04. im really sure my dads 07 base has none however
Swapped the front brakes out on the Regal. 60K and the outer pad on the passenger side was just finished. All others had about 1mm of pad left. Tossed in an oil change for good measure.
From what I understand, an inline setup is best for those of us in northern climates.
Most of the time if you're in zero degree weather are you going to revving to the moon or trying to do bracket race in the ice you're going to warm up your car which also warms the transmission by the time you getto where you gotta be you'll be at or little below operating temp. I had one standalone on my gtp when I was in Colorado winter or summer I never had issues.
I didn't see anything about how the standalone regulates temperature in any of the writeups I saw. I wasn't sure how to size it correctly to achieve the correct temperature.
And yes I do drive fast in the snow; tires spinning a lot of the time (there are lots of idiot drivers to get around). 7 miles to work the trans doesn't usually warm up much so I need all the help I can get.
Stand alone cooler makes a huge difference...I've had both stand alone and inline ones and definitely a huge difference with my current stand alone cooler
Cursed at the starter bolt that wouldn't come off smh. Tips? I left my breaker bar at the other house.
Sent from my HTC One using Tapatalk 2
Status
