Used BCMs cannot be reprogrammed. They are vin locked. When new you only have so many ignition cycles before the unit is no longer programmable.
Sent from my SPH-L710 using Tapatalk 2
Simple answer for guys that need one and don't want to buy one new. Then receive it and realized that they just wasted their money and should of done more research. Just get a new one and avoid that.
Update... I hooked up an Autel Automotive Diagnostic Scanner to the car yesterday and got the following diagnostic codes: View attachment 12169
Is it worth trying the PCM security relearn procedure? I am unsure if this will fix my problem but maybe it is worth a try?
Youll have that code in the pcm because it saw the loss of that fuel enable signal from the bcm. (one more indication) your pcm has nothing to do with your no starting issues.
My advice for you would be find the part number from the dealership. (call the parts department) give them your last 8 of the vin and let them give you the price, then ask what the part number is. Then google that part number find it cheapest you can new. Take it to a dealership (or shop with tech2) with your car and programming should be a typical hour charge. Youll walk out for less than $100 labor. Problem solved.
Ok. What part are you referring to? The BCM? I did call the GM dealership closest to me and they told me they will reprogram the BCM for $110.
