Delilah....dyno rackar
Re: Her names Delilah......wobble wobble wobble
Which bolt exactly and why? Just curious not questioning ya
I used to have that problem on my 91 park ave when I tried solid metal lower trans mount. However I had a leak just like that and couldn't figure it till I went to check the tourqe on the bolts afterwards never had a leak.plus while you're at it you can change that lower mount you've been needing to change.
Yea I know I need to change it. I want a solid one or something better than stock. But I guess if I decide to do LCA's then I'll do that then. Will a wrench not fit in there
some people claim to have done it like that but to me id rather get it done the right way..
what made you start looking at your front end? i have a slight wobble in the steering wheel around 45-55mph
To be honest I figured it was front end due to the way its only in the steering wheel. What else could it be. I open to ideas
so you feel it only in the steering wheel also? just a slight shimmy you got?
No its a little more than a shimmy. If I let go of the steering wheel its about an inch side to side back and forth during those speeds
so maybe mine is in he early stages of this problem, mine is slight back and fourth, car drives straight as an arrown though
Yup. I really hope its not the steering intermediate shaft as those are a pain to replace
yeah that would suck big time, let me know if your issue is that cause with the same thing happening i wonder
wasnt there a gear in there that goes bad? i rember my 97 having it replaced on recall becasue of someting. Not the issue here though
No the shaft doesn't have gears. Its like a drive shaft on a jeep sorta with the way its designed
