He said probably anywhere from $1200.00 to $1500.00![]()
He said that would be the cost of the kit when its done.:th_nanana:
What I'm asking is how much he has spent out of his pocket, and how much time and effort he has put into developing the product, ect.. :th_peaceout:
Good stuff. I liked the cogged idea but i dont like the idea of messing with the oil filter location too much. Unless its really easy to space out the oil filter or relocate it.
Does the crank pulley have to be that wide? Looks great though and you got it to work.
Roughly around $1,800.00 in materials and tooling I would estimate. My time, invested into it, priceless. I am not keeping my hours logged at all, or adding that into the over all price. Lets say, there was about 3-4 months of planning, and research, and then around 2.5 weeks worth tooling off and on. Then now that its made...just little adjustments here and there brushing stuff up on the lathe, or creating a few new different pulleys to try out.
Don't think I am some well off guy with a career or anything. I work full time, go to college part time, working on remodeling my home...bust-busy-busy. I'm only 28 and still earning.
~F~
Same thing here...but I have to counter act, the need of the belt to want to float out of the grooves, cause its a bit tricky keeping things perfectly in line, and not slide out of the teeth, off the pulley. Serpentine set ups...only way this happens is if you don't set the belt in the right grooves when you install the belt, will it track wrong.
Can't add ridges to the edges of the cog'd pulleys?
