what are the benefits of an egr delete?
Doug 97 gtp
i was justing thinkint to my self if i did an egr delete i will throw a code right? and what are the benefits of deleting it ?
cleans up the engine bay a lot.
setting the code to no report is super easy.
and loss of mpg is more prominant with misuse of your right foot than the EGR delete would do.
My thinking and you can take it with a grain of salt... I deleted my EGR and had it tuned out of my PCM. Why:
1) Cleans up the engine bay a lot
2) Opens up area to work to change plugs LOL
3) MPG are not noticed in around town driving.. you might lose 2-3 MPG highway driving
4) And most important to me, I now do NOT have hot exhaust running through my intake into my cyl's...
I am trying to keep the air as cool as possible so my thinking was, remove EGR, no more hot exhaust gas.. :D Now is my thinking right, who knows.. LOL But made sense, and looks better..
Actually, the HOT exhaust gases (inert) COOL the combustion... But I did it to get rid of the residue it leaves in there...
The EGR is not always open, it only opens at certain times based on speed/rpms/airflow etc etc. So the only time the hot gases that help cool the combustion is when cruising around like on a freeway.
EGR is suppose to help reduce Nox emissions. That is the main goal but it also helps in gaining 1-2 MPG and really only opens during cruising. i think 04+ GPs' benefit most by deleting it because of the Throttle by wire. I have seen several GP's have hard start no start issues and ended up having to clean out the throttle body with carb cleaner and a rag as a fix. The egr inlet in the intake is right after the THrottle body and coats it with carbon build up bad.
