I ges ill have to stock up on fuses and try everything possible and hope for the best. Also when I start my car in daylight only the driver side hid turns on. If I start it up in the garage or at night both work fine. Have you experienced this?
I re-attatched all the wires (relay harness and everything) didn't blow any fuses the passenger side turns on and the driver side flickers a few times then shuts off. Could the passenger headlight be robbing the driver of power since its closer to the battery?
Hmm I have two relays too so maybe ill have to try this then! Lol I can only hope thoughI swapped out ballasts and bulbs tried everything but the driver side still flickered. When I ordered my harnesses I ordered two so I thought of trying both (one per side) and what do you know its works! So Spazzz your one ground per side idea would probably seem to be the fix for me (except I used two ballast but essentially Im running one ground per side).
Less resistance in the wires would be my guess.Lol yeah ive seen a lot wirh the 2 grounds but honestly I dont see how itd be a difference, but ill give it a shot! So id just hook one relay to one ballast n leave the other connection taped up or something n then same with the other relay and ballast?
I cut my single ground and made two grounds and it works but i still have flickering when lights are on auto mode. Did some more research and we need to pull the drl fuse for 05 and earlier models and 06+ disable the drl system because when the ignition is on drl system uses 5v and pulse width modulation which explains why the hids flicker.
I found a guy on another forum site that did a write up on this.
ClubGP Message Forum troubleshooting
He has a good write up
