most likely the tensioner, they go bad frequantly.... spary some wd on the center (WHERE THE BEARING IS) when running and if it changes the squeak you've found the culprit...
X2 on this, Usually if a water pump is going to make noise it might sound like a shallow knock or rattle. Most of the time water pumps bearings will go bad, destroying the seals or visa versa and leak coolant.
Did you spray some WD40 around like was mentioned before?
it woulda been a big time saver....:th_scratchhead:
Totally!! It's funny when folks come on here and ask questions to get tips on how to diagnose something, and they don't do what is suggested. :th_shakinghead2:
ehh whatever the car just turned 67000, im sure stuff needs to be replaced. i wanted to replace both of them, oh well
