brando just got a F on lim jobs from me........rtv on the lim bolts? wtf? forgot to dab rtv on the lim corners? again wtf lol
Bro.......
Don't u have a v6 ?
I'm calling trolllll on that post
RTV or teflon paste? RTV may be a catch 22. If you break the seals they made, you might cause leaks since RTV doesn't stay workable, it dries. And trying to clean it out of those threads may allow some to fall inside the motor. Those holes go into the oil and coolant passages.
Dan on retightening. Please don't go past 15ft lbs on the LIM bolts and 20 ft lbs on the SC bolts. I've seen guys break or strip them. Those are the two specs that I use when replacing LIM's.
PS.. Nice on the workout.. :th_thumbsup-wink: Didn't have to get all grumpy with me .... I was busting your chops, cause it read like you had found the issue.
Well.. if you don't have a torque wrench, I'd suggest getting one. It's a great tool if you plan to work on a car.
You scared me (I know you body build), thought you said you were gonna really torque them down. Might have been a lack of caffination. Reread and I'm confused if Brandon used a three finger rule...and if that's pretty loose.
At this point, I'd suggest pulling the charger. Then check the LIM bolts to be 15ft lbs. Don't pull them or apply anything else. The RTV isn't a big deal, but cleaning it might be a pain. Make sure the gasket surfaces are clean, mainly free of any bumps.
Then once you pretty things up with paint. Torque the SC to 17-20ft lbs and call it good.
