I think it looks good, does have the monster logo feel.
definately adds another hp or so in your sig
^lol^And i fixed it for you Sir Spells a lot
you had moster
i soldered some wire in the factory harness to extend itWhat did you ever end up doing about the rear o2 sensor when you install the SD?
u welded in a cat?
I believe he's running the test pipe and had Bill delete the codes
It's a 04 you gotta at least have the rear o2 sensor plugged up but you can have someone turn the codes off if I understand it correctly.
