since i was out here i grabbed one of my dbw tb's out of the dbw tb bucket and stuck a caliper on it.
center of shaft is at .390, the end near the bearing is at .393, 9.98 mm
the tb bore is offset, it is not a straight through venturi design, it is a butterfly inside a sphere with an increasing radius, this allows the throttle blade to mave at each individual stepper position but the bore/airflow path doesnt change but a hair, once the blade is at about 12-15* those spherical ramps disapear and the straight section of the bore is presented to the blade. early tb's had a spherical shelf riveted onto the bottom of the blade (leading edge) to do this with a straight bore. you can remove the shelf from these early ones for much better flow but it will have the notchiest idle youve ever experienced.
the later ones would probably have a had time passing a 70mm od shaft straight through the bore axis centerline due to the spherical offset at the blade pivot centerline.
so yeah its a 75mm on paper, but it aint. tis why i played around with the 90mm dbw with our external TAC
