ZZP PCM Tune
GrandPrixGT1
Has any one used the ZZP PCM 1.0 Tune? That's whats in my car, 2002 GP GT. Everyone on w-body has said that those tunes are crap. I didn't think much of it until I watched the knock retard while doing about 75% throttle at 60 mph. highest it got was 6.5 but was switching back and forth between 4.6 and 6.5. Has anyone else had issues with their tunes?
GrandprixGT1
cool club huh? kr will come and go with throttle or the timing its set to as it raises and lowers with the rpm's.
whats your mod list?
Mods include
ZZP PCM Tune 1.0 but that will most likely be removed
ZZP 2.5" Downpipe
K&N Aircharger
ZZP Throttle Body heat shield and Spacer
Aeroforce Scan Gauge
Performance Shift
Front and Rear BMR Strut Tower Brace
zzp likes to turn the timing up to 18º on most of their tunes, that might be to much with out better flow mods.
if you still have the stock pcm, pop it back in see if its less kr.
Ok that's a good idea I'll try that out this weekend. I hope that's going to help it.
kr is bad, if you have to much timing it will knock, knocking can chip pistons, so you want none or as little kr as possible. stock timing is 15-16 wot top of the rpm's.
for every degree of kr the pcm see's, it will cut out 2 degrees of timing, making it fall on its face in an act to save its self from the kr.
so if you have 6 to 8 degrees kr, the car will feel pretty weak due to its only running on 5 degrees timing when the kr kicks in.
Huh interesting. I still haven't heard back from ZZP I'm hoping they aren't ignoring me. I may send them an email tomorrow again if I don't get anything. Car feels powerful but that's probably because it shifts 2 gears when you punch it and end up in higher RPMs
