That is what I meant by programming mode, as back in '07 that is what ZZP told me I was experiencing by the DIC flashing 0.0's...
And since it was the ONLY factor that changed...it was deemed that was the issue
#3 piston chipped at the 1:00 position...the same as 99% of all the chipped piston locations. Thought that was it...cylinder walls looked fine. Thought we could just swap the piston and be fine but when the oil pan came off the entire skirt was gone.
And toasted meaning, blew up...you know what I mean.
No..
You can blow a headgasket, blow a piston up, chip a piston, blow a wrist pin, shoot a rod through the block, get rod knock, break the crank, drop a valve, break a valve spring, wipe a cam bearing, break a timing chain.... I can keep going if you wish.
You also probably never meantion that this happened almost 4 years ago...
Timeframe has plenty to do with it. Things change. If you say that you had 5 PCM's where all had the same issue you don't believe they would investigate the problem further.
I'm still curious as to why you continued using the same company after the issue was still there with the 2nd PCM
And people think their engine is gonna blow due to the safely modding your car thread. Your comments in regard to ZZP scare people into believing if they use the same company for a PCM then they will have the same issues you did.
I'm stating what happened to me, take it how you will.
While you may do that in this thread, you have made it VERY clear in others that you are speaking for a large group of people in the context of zzp pcm's being very bad.
That for every ONE thing that is done good, you hear TEN BAD things
