FoSHO99
youtu.be/xhrBDcQq2DM
The higher pressure may cause the seals to blow on the turbo prematurely, then you have to get the turbo rebuilt. The restrictor helps this from happening, but you should put another filter before the restrictor like tengis was mentioning. If anything small gets stuck in the restrictor, the turbo is done.
