ZZP MPS Install questions
Liquifire
This is probably a ridiculous question, but I want to be sure before I attempt the install of this MPS. This is an eight rib MPS from zzp. I have a six rib belt...question number one-is the belt centered on the pulley or does it go more to the inner or outer? question two-after pulling the stock pulley and installing the MPS hub how do I know when I am at the proper mounting depth for the hub. Does it only go on so far, or how else do I know. Thanks for the help once again guys...
i centered mine on the pulley, but if it isnt sitting right it will move itself when the motor is running.
i put the hub on flush with the end of the snout so the pulley was the thing hanging out the farthest and the pulley will sit flush with the end of the snout as well.
