hmm I'll have to try that then I'm assuming the motor has to be pulled pretty far forward to fit it through the top?
That or pop the trans dip stick out. For SSAC/SD that's the trick. The instant that is removed, the header drops right in.
I was under the impression the ZZP headers generally require some bending of the trans dip stick to clear the header.
does the trans dipstick just pop out? because I can prolly get the header in if that's the case
ok I'll check that out I'm ready to get this thing started up , was it a good improvement when u did headers?
That is a resonator, keep it. You gain nothing by removing it, it keeps rasp down.
Its after the flange anyway for the cat-back, so just bolt it up like normal and be on your way.
