zzp fuel pump rewire
Hawkman
Hey just wondering if someone can get me pictures of how they did there wiring for the rewire and what wire they tapped into i kniw the instructions say the gray wire but? really zzp! ipulled of the fuse cover block and see the gray wire that goes into the pannle and cut it to have a little extra hanging out and hooked up the bluewire to the wire coing out od the fues box. hooked the rest up in the back installed new grounds and car starts and runs for 3-5 sec and dies the power to the pump stops wtf is going on? am i missing something or doing this wrong ? Thanks for any help
When cut the gray did you splice both ends to the blue wire or just the one coming from the fuse box?
I personally didn't like the zzp rewire, it was poorly made. The Casper rewire, found from Wbodystore, or the racetronix, found on prj performance, is a much better quality rewire.
i did not splice both ends only the one coming out of the rear of the fuse pannle. If i known how crappy it was i would have went with one of the others now lol. live and learn! so splice both to the blue wire then your saying? thanks
