zzp canned tune
hollas13
Alright question is when zzp says they bump the timing up to 18* on there 1.0 standard pcm where do they add the timing at?
so if im getting between 1*-2* kr at wot its from the extra timing they added then right? im running 93oct, 1.9's, 3.4mps, al103's, headers, 180* tstat, hai and the zzp tune. if that helps. just trying to figure out where this kr is coming from. 98gtp
mail order tune there basic pcm with the line pressure changes wot fueling and timing. said it would be good for a basic 3.4 setup. i know all cars are different and the mail order just gets in the ball park of where you might want to be at. i know nothing about tuning just wondering if the added timing would cause kr. if so i would bring the timing back to stock next time im in ohio.
Where at in Ohio?? I am in Cincinnati and could help you update the tune if you'd like. Could take some data logs and try to dial it in.
dang toledo about 4hrs north of you. ive got someone in toledo that has hp tuners thats gonna help me the next time im back home. im living by baltimore now tho
It would also be good on an extreme heads cam setup too.
