    TIPS:
ZZP 3.5" pulley, trans mounts, Vinnie Spacers, L67 to LS1 Kit, Gen5 to l67TB adapter
buickman104
Items will be shipped from Sunnyside NY 11104.
1 L67 to LS1 throttlebody adapter kit with modded LS1 TB (for more flow) and no cruise control bracket. Great for people with ported gen3 blowers or someone looking for sharper throttle response from their l67.
Kit includes
- adapter plate
-throttle bracket adapter
-modified LS1 throttlebody to work on FWD applications without cruise control! and modded for more flow over stock LS1 TBs.
(needs a tps sensor that can be purchased at rockauto for $20)
$120 Shipped or best offer
2 Brand New Transmission mounts
DEA Part # A2712HY
$18 shipped! each
ZZP 3.5" pulley $50 shipped
Vinnie Cradle Spacers $50 shipped
For those of you who are low and experience axle vibration this will do the trick to help align your axles properly again.
If you are upgrading to a gen 5 blower and want to keep your stock throttle body then this is the adapter for you!
$65 Shipped Sale Pending
Sandblasted l67 Throttlebody. Includes all sensors when shipped. $50 Sale Pending
Items are sold as is as shown in pictures. Add 3% when paying through paypal.
Re: L67 to LS1 Throttlebody adapter kits
Do you know what the difference in area is between these LS1 throttle bodies and the standard L67 units? Do you have a MAF table associated with them to drop in to the tune when switching over? Thanks!
With the LS1 tb we use the standard LQ4 maf and when I ran these started with a base LQ4 maf table and tuned for adjustments from there.
The stock L67 TB has a 67mm bore. the LS1 TB has a 75MM bore. also the LQ4 Maf table is in the DHP power tuner files .
Re: ZZP 3.4" pulley, trans mounts, Vinnie Spacers, L67 to LS1 Kit, Gen5 to l67TB adap
Do you still have that transmission mount?
