ARFF22
Finally bit the bullet and ordered the Z7 Turbo kit and since I am totally new to the turbo game have a couple of questions. Ordered the Z7 kit with the inter-cooler and front and rear power logs, since I have SLP Headers and I know they are not compatible with the kit. I have a stock L36 engine with an SLP Cat Back exhaust. My first question is, what is the best/safest setting I should set my boost at? I've seen that these cars with the Z7 kit can pretty much be safely set-up to run anywhere between 6lbs to 15lbs of boost? So what should I set the car up at, it is a daily driver and I do not plan on racing it, just want a quicker car. Secondly, I ordered the Boost Controller with the kit and the controller looks pretty straight forward. But I do not know how I will know how much boost I'm running or adjusting? Am I missing something? The manual boost controller is pretty simple in that you turn it one way to add boost and turn it the opposite way to decrease boost. So if I want to run 9lbs of boost, for example, how do I know how much to turn the controller and/or which way to hit that boost amount? Thanks in advance for the help
